I'm just relieved it's a such a minor matter. The thought of shipping this back and being without for 10 days or so actually shuts down my brain. If I think about it I just collapse in a pile right where I stand.
Chris
Randy G. wrote:On the VBM's, the E-61's midpoint lever position opens the HX and water path and allows the pressure of the heated water in the HX to be released into the brewhead and onto the coffee.
cafeIKE wrote:The mid position on an e61 does nothing. Nada. Zip. Zilch. Only if the lever is moved so the cam engages the valves will water flow. Whether the pump runs before or after the valves open is a mechanical adjustment.
erics wrote:When I lift the lever from the fully down position to the mid-position (audible click and you can certainly feel the detent), the hx is open to the group and any pressure build-up in the hx due to expanding water is immediately dissipated and water flows through the group.
erics wrote:On the Quickmill machines, it's a different story. Or perhaps, I better say, on my Anita, it's a different story.
erics wrote:Absolutely, I agree with your definitions; its just that the QM machines apparently give a little nudge to the brew valve when the lever is in the mid-position. And, it seems, a little nudge goes a long way.
jgriff wrote:So maybe every machine, even similar ones from the same manufacturer, has its little quirks?
