Eric, could I have a TC at the head and another at the boiler and still have the ability to control the boiler with one PID (dual readout) at the tank and view the water temp at the head as well. Any clue how much of an difference of temp between the screw and the PF?
Yes, but that is a relatively expensive PID as it is a dual loop control wherein you are simply monitoring one of the loops. There are probably several manufacturers of these - one that I am aware of is the Love 32DZ. Applying a PID to a hx machine has been discussed on this forum. See the heat exchanger section here: http://www.home-barista.com/espre...vorites-t1541.html
Monitoring grouphead temperatures should be a separate issue. As far as temperature differentials are concerned, I do believe that these machines behave similar to the Rancilio Silvia and a good read on her temperatures is here: http://www.home-barista.com/espre...out-pid-t4691.html
