Just reserved one this morning!
http://www.chriscoffee.com/products/home/espresso/izzoduettoIve never owned or used an espresso machine so I have a lot of questions.
I know that grind and tamp are important and I have already decided to go with a Macap M4 to compliment the Duetto. I have a Virtuoso for drip and would rather just have 2 dedicated grinders than re-calibrate the Virtuoso.
So as far as tampers go, is a flat bottom or convex better for this machine? If flat bottom is better than I'm thinking either the 58mm Motta or Reg Barber. I'll probably have the tamper and portafilter fitted with exotic wood handles so if the Motta base is the same specs. as the Reg Barber than I'll just go for the Motta:
http://www.chriscoffee.com/products/home/espressotampers/mottawoodhandletamperReg Barber:
http://www.chriscoffee.com/products/home/espressotampers/regbarber I was thinking of using a click mat to help me learn how to tamp. Does anyone have a user based opinion about this:
http://www.chriscoffee.com/products/home/espressotampers/espressogearclickmatHow many grams of coffee do you use for a single shot? What about a double?
What is the proper temp/pressure to pull a shot?
If frothing milk, for best results I heard to use whole milk and do not steam it past 165 F. Is this correct? I'll start off with a thermometer until I can learn how to do it properly.
I buy my beans from a few different roasters here in Chicago. Metropolis, Star Lounge, Intelligentsia and The Coffee & Tea Exchange. Is there a specific type of coffee that "should" be used for espresso? IE: Redline, BlackCat. For drip I like Sidamo, Tanzanian Peaberry, Rawanda, and on and on. Am I likely to pull a good shot with one of these?
