gj91 wrote:I have looked at a ton of these now between HB and Coffeegeek. I am going to give a non-liquid gauge a shot. I am going the flow through route. Otherwise I am going to get one of the liquid filled ones. I just don't see the liquid filled ones at local hardware stores. I am going to try HD and Lowes.
I first need to test my Silvia then I will probably have to get the new OPV valve if I need to adjust. It seems that 9 bar without the flow is a good target, that means it's a little less when there is actually flow.
Well, here is my contribution. I used a non-liquid pressure gauge from Sears. It was on the air compressor parts isle.
First I tried to put a bunch of stuff on but there is no room to turn the portafilter so I opted for an Elbow connection and reducer to fit the 1/4" gauge and it worked just fine. No dancing around on the gauge and a solid 10 bar after it touched 11 bar but settled back to 10 bar. This was blind too.
The only time the gauge danced around was when I would test again without emptying the water. Other then that it worked fine.
Now I'm not sure what 10 bar means. Probably around 9 bar if it was flowing through which isn't bad. not sure if it's worth getting an adjustable OPV valve and get it down to 9 bar.
Here is my photos. I need to clean Silvia up.
