Since people in this thread known a lot about plumbing (everything I asked about earlier works now, by the way, so a big thanks!), I'll try to tack on another question. I'm trying to adjust the inlet pressure to match the machine's specs, and was wondering about pressure loss.
I run plumbing for the machine in the basement (filter, etc.) and then up through the floor into the dining room where the machine is. My pressure gauge is in the basement (after the filter and regulator) and reads around 45 PSI. The entire system is 1/2'' PEX tubing, and after the water runs through the PSI gauge it goes through about 30 feet of tubing, 5 feet rise (from basement ceiling to machine on 1st floor), and a few sharkbite fittings (elbow, shutoff valve, tee [to tee off some extra tubing to another valve that lets me draw water next to the machine ... sort of a makeshift faucet], 1-way valve, and a fitting to reduce the 1/2'' to the 3/8'' machine hose.
I'm wondering how much pressure I lose in this setup. The 5 feet elevation would by my calculation cost me about 2.5 PSI, the fittings and tubing maybe a little more (though I don't have a good sense how much, esp. whether the 1-way valve leads to PSI losses). And my main question: what happens to PSI when the line is reduced from 1/2'' to 3/8''? Common sense tells me that pressure increases (water flow gets compressed into smaller space), but at the same time, there's added friction in the reducing fitting that might actually decrease pressure.
I could hook up a second gauge close to the machine, but before I go buy one of those, I wanted to see if anyone knows how to calculate (or estimate) pressure losses. Even with a second gauge it'd be nice to know how water pressure behaves in these common plumbing setups
