BSPP fitting for 8 liter water softener by expobar
Postby beddu on Thu Apr 14, 2011 7:18 pm
This is my first posting.
I recently purchased an 8 liter resin water softener. I would like to build a water station in the basement where I can go to and fill jugs. I cannot plumb the softener to my machine upstairs, because there is no room under the sink
So my question is where I could find a conversion fitting that has a BSPP 3/8 female to a 3/8 NPT male. The female would screw on the softener and a braided stainless steel hose with a 3/8 compression fitting would screw to the 3/8 npt male.
I believe these softeners a quite common in espresso bars but they are hooked directly to the machines, but because my objective is unconventional... I'm running into a nightmare.
I hope someone could help me
Gaetano
beddu
Postby erics on Thu Apr 14, 2011 9:08 pm
Here's the part you described:
http://www.adaptall.com/products/brass/8037.html
P/N 8037-06-06 . They are a Canadian manufacturer that sells to distributors. They will gladly tell you where to go to get the part.
Skål,
Eric S.
http://users.rcn.com/erics/
erics
Postby beddu on Thu Apr 14, 2011 10:45 pm
Thanks for the quick reply Eric. I will follow up with them tomorrow.
Gaetano
beddu
Postby DavidMLewis on Fri Apr 15, 2011 1:05 pm
Hi,
The part you want is also available as McMaster-Carr part number 4860K153, on this page. US$16.14.
Best,
David
DavidMLewis
Postby erics on Fri Apr 15, 2011 1:47 pm
David is correct.
Unfortunately, McMaster-Carr will not ship to Canada for new accounts &, BTW, they purchase the item from Adaptall - a little unresolved discrepancy between BSP and BSPP but . . .
Skål,
Eric S.
erics
Return to Espresso Machines
