Dear members,
I've got a badly misswired FRANCESCONI MC1, which is built by Brugnetti.
The difference is the vibrating pump (Fluid-O-Tech 70W). I found a lot of faults and corrected them. The 3-way valve magnet is bad and I ordered a new one . I'll get it tomorrow. The machine is boiling now but the pump does not switch off. So it overfills the boiler. There must be two ways to control the pump. One is for brewing and shall switch together with the 3 way valve after the pump. The other should be controlled by the level sensor and shall open the 3 way valve to the Boiler (no power) and open the fill valve on the water inlet. The sensor shows a resistance of lower than 10kOHM which I believe is ok when full. The controller is the GICAR BOX E.T.30 EM 1GRC (see picture). It has a GICAR keypad with 5 Keys and volume dosing.
As I have no knowledge of this unit and I don't know how to program it, a brief description of the keypad functions would be very helpfull.
As important would be a wire diagram of a MC1 machine of any type
Thanks
Hans
