by gscace on Tue Aug 18, 2009 10:20 am
Hi.
It's pretty hard to understand this post. Was this a redirected post from somewhere else? Anyway, to answer your question, the pump should rotate by hand pretty easily.
I'm not sure if this is likely your only problem. The guys at Chris' Coffee are pretty good, and I don't feel that second guessing them is gonna be helpful.
My question for you is are you feeding the pump from a flojet, or from water mains pressure? If flojet, you may need an accumulator tank.
-Greg
