by Randy G. on Fri Feb 05, 2010 6:57 pm
I have dealt with a number of stuck parts dealing with cars and motorcycles over the years. You should have seen what it took to get the fill bolt of my Volvo's tranny since some idiot over-torqued it while it was hot...
Anyway, without being able to look at it (if you have a link to a picture of the part, that would be of great assistance), and basing the following advice on that photograph from you , here's what I would do, assuming that the broken fitting on the boiler threads into the boiler and it not brazed in or in any other way permanently attached:
1 - Try a quality penetrating oil. This assumes that the boiler is going to be cleaned thoroughly afterwards, and that the heating element is already removed. I wouldn't want that stuff on the element.
2a - Heat and cold are good allies in a case like this. Slowly heat the area with a small (propane) torch, and using a small hammer continually and LIGHTLY tap on the fitting while heating. We use to be able to free the nuts on corroded battery hold downs with that method, just using very hot water.
2b - If 2a didn't work, after heating, and while still hot, apply a chilling spray (or ice, or dry ice) just to the fitting and not the boiler. Then immediately try to tighten (just a tiny amount) and then loosen the fitting. If that doesn't work, repeat 1 and 2 again.
3 - That fitting is held in place, not only by the sealant and possible corrosion, but also by the stretching of the threads. A lot of that force is against the head of the fitting against the boiler's surface. As it was tightened originally, the head stopped moving towards the boiler's surface, but the threaded portion kept turning. This places the threads under tension. Removing the head (the exposed hex end) of the fitting will release a lot of that tension. After that, using a reverse tap may back out the remaining portion of the fitting still in the opening.
4 - Worst case, since it is just a drain, you could have another threaded insert brazed into place.
