Brewing around 10 bar, but would 9 bar be better?
My Quick Mill Alexia w/ PID is brewing around 10.1 BAR should I disassemble the panels and switch the OPV to bring it down to 9? I know 9 BAR is the standard but has that changed. I received the machine with it being at 10.1....I'm pulling tasty shots but wasn't sure if 9 would be better?
Braden
Braden
as long as you're getting tasty shots, i wouldn't bother.
LMWDP #630
For me, a too high presssure will cause the espresso shot to be more like a punch in the face with flavours rather than delicate. Finding that sweet balance where you don't get too strong of a taste and not to weak is what I think is the most important thing. I've tried brewing up to 10 bars on my rocket evo but find it tastes too aggressive. So I lowered it back down to 9 bar as it was set by the manufacturer. What really matters is the flavour. Try the different pressures and see which one you like the most.
// Robin
// Robin
+1 brewing at lower pressures (8-9 bar range), tends to produce smoother shots, but it's all a matter of preference. If you like what you're making then why bother...ya know? If it ain't broke, don't fix it...unless you want to experiment.
LMWDP #748
I say adjust it, compare your 10 to 9 and even 6. Leave the panel off for a week and experiment around. Then stay with what you like best. Only way to find out what ya like best.
I've switched back and forth on mine between various pressures. 10 and 9 bar wasn't much difference. In fact though, your 10 bar on the gauge is probably more like 9 or 9.5
