HB wrote:It's possible that the GFI outlet is defective. The more likely cause is the GFI circuit is doing its job - tripping to protect you from a short in the machine. Before you go on a loose wire hunt, I recommend getting on the phone with Chris' techs. They may have other ideas, or at least a short list of likely suspects.
I spoke with a very helpful tech at Chris' Coffee, but we were unable to isolate the cause of the problem since it only happened at warm-up then was OK after that.
Now today, it is no longer an intermittent problem. Vetrano is dead!
Just plugging it in (in the off switch position) will trip the GFI immediately. I tried several outlets, so it is not a bad GFI. I am suffering withdrawal already! At least I can make myself some good Turkish coffee to help soothe the cravings.
Of course this happens on the weekend. I'll call on Monday to see what the next steps are. Bummer.
If I need to ship it back, how would I drain the water from the boiler since I can't turn it on? (or would I need to?)
Richard
