DolceVitaBaby wrote:Hi, I was working on a Brasilia 3 group Century machine that had an odd problem with the motor or pump shuddering, so I decided to test the motor capacitor, and I DID NOT REALIZE that the leads to that are HOT, with the result that I touched one lead to the motor accidentally - something shorted out or a fuse blew - the dosing keypads no longer work, but the BOILER does get hot. Ok, what is the likelihood I blew a fuse or an internal breaker (which I cannot find) Or I blew one of the logic boards, and I AM
CROSS POSTING THIS ON COFFEEGEEK! Ok need comments ASAP, thank you.
You are in LA; what a coincidence!
Call up Michael Teahan and Angelo Minicozzi, who run a parts business in LA called Espresso Resource. Both are certifiable geniuses, and by total coincidence, both used to be employed by Brasilia as technicians and machine designers.
They should be able to tell you what you have done to the machine, what are the parts you will need, and coincidentally, to sell them to you.
Their number is: 818-786-7179. You can tell them that Ken Fox recommended them on Home Barista.
ken
