First time post so bear with me.. I did search the forum for similar problems but didn't find an exact match.
Just the facts:
Brasilia Portafino 2006
Changed the filter on the direct water supply line. There is full flow out of the filter.
When I turn on the unit I hear the pump running until a red light starts flashing by the "Stop" button, then the pump shuts off.
Sightglass is empty.
I do get water from the hot water tap but at a lower flow rate than usual.
I get water at the portafilter.
I get steam at the steam wand.
(again) Sightglass is empty.
The manual fill button at the front of the machine does not work to fill the sightglass/tank. At one point it began leaking profusely at the button (on the front, / lower panel of the machine), but it seemed to seal back up.
Do you think this is a pump problem? Or is there a solenoid or other valve that would be preventing water from reaching the tank properly? Is there some testing I can do to troubleshoot to give you better info here?
