Bottomless portafilter for Elektra T1 - Page 2
Postby da gino on Sat Nov 05, 2011 12:33 pm
You can also get a nice bottomless from Stefano that works well on the Elektra.
da gino
Postby cannonfodder on Sat Nov 05, 2011 11:45 pm
malling wrote:Thanks
so the Pf you are using would that accept the Elektra handle. They bouth seem to use the same standard 12mm bolt.
12mm is relatively standard. The Rancilio portafilters use a very odd setup as do the Gaggia's. The LM GS3 portafilters use a M10 stud where the rest of the LM line uses a M12. LaSpat uses a M12 but a fine pitch thread and the lever machines tend to use an odd size. The Elektra lever uses a M8 on the portafilter and M10 on the lever but the Penny bottomless portafilters use a M12 but the stud is part of the portafilter so the handle is female, as are most lever machines.
cannonfodder
Previous
Return to Espresso Machines
