sunnyu wrote:The vaccum valve is fine, whats more my temp stays at a consistent 190 shot after shot. i even bypassed the sfatey thermostat in case it was sending a false signal. But your slant made me think, could too much or too little water in the tank case similar symptoms to air lock. i.e. getting too much pressure without the corresponding heat.
I think it is pretty simple; if in fact you are measuring boiler water temperature, and there is no vapor/air lock in the boiler (e.g. "false pressure"), a boiler pressure of 1.5 bar or above does not equate to 190F. Therefore, either your measurement technique or the front panel gauge are wrong. As a result, you either have an error in your measurement technique or your front panel gauge is giving you erroneous information. The fact that the safety thermostat triggers just above the 1.5 bar setting (if I got that part right) would indicate to me that you would need BOTH the safety thermostat AND the FPG to be malfunctioning in order to explain the problem in any other way than that you are not getting an accurate measurement of boiler temperature.
So, I think your measurement technique is flawed. By the time that water comes out of the water wand or the steam tip, it is going to be at no more than the local boiling point or it will not be liquid, it will be a gas. Water boils at 212F at sea level and less than that at elevation. Therefore, the only way to measure a boiler temperature in excess of 212F at sea level would be under pressure, such as with a thermocouple INSIDE the boiler.
Venturing a wild guess I would say that your measuring technique is faulty or you are losing at least 22F (if you are at sea level) between the boiler and the wand exit. You may also have a faulty measuring device. The problems with your espresso taste may have nothing to do with any of this.
Sorry, but I have run out of ideas except those above.
ken
