erics wrote:So, let the boiler come up to full pressure and, on the way to this, manually activate (fully) the safety valve with a piece of wood. If you're lucky, this will clear out "some crud in the valve seat causing a steam leak, rather than a problem with the spring."
I depressed the valve with a wrench on its way to full pressure. As soon as full pressure was achieved, I released the wrench, and there was a strong discharge of steam. Scared me for a second.
erics wrote:If you replace the valve, replace the copper washer sealing the valve to the soldered hex beneath it. But you really need to remove the valve before ordering a replacement because it is either threaded 1/4" BSPP or 3/8" BSPP and its hard to know w/o removal. The size of the soldered hex could be a clue but it can also fool you.
Any tips on removing the valve given that it's soldered on? When I had the boiler off, I put a crescent wrench on the valve, and hit the wrench with a hammer so that it would turn CCW, but even that didn't loosen it up.
