beatstanfurd wrote:Anyone tried radiant barriers for insulating the boiler? Reflectix is one brand that is carried by big box stores. I'm assuming the instructions they have on their site for insulating water heaters can be easily modified for boiler application.
water heater application instructions
The polyester used for heat mitts (as described above) has radiant barrier in it. Look at the picture of the wrap and there is the hint of the inner radiant barrier
The bubble pipe insulation carried by the big box stores was not spec'd to handle the 300F temps, so I did not test it. There is a foam sandwiched in reflective material used to insulate metal buildings that is spec'd to >300F but the sample arrived (50ft sq min to buy) after using the polyester and I did not feel the need to test it.
Floyd
