I spent some time yesterday monkeying with the autofill probe in my plumbed in Cimbali Rotary Junior D, which (unfortunately) has boiler autofill. Did I ever tell you before that I HATE autofill?
I learned a number of things including that it is hard to get the autofill set at a lower level than a certain point, because the probe simply can't make the curve into the boiler when bent beyond a certain angle. I could experiment with more rounded curves, but since these probes should be cleaned occasionally (even soft water will put white powder on the probe which interferes with conductivity) so you do need to be able to remove and insert them, and whatever you do should be repeatable, unless you enjoy doing shot curves with a Scace device. Finally, the autofill doesn't set an exact level, rather it sets a range. Depending on the level of the fill asked for, at least in my machine's boiler, that range has a "slop factor"of as little as 3 and as much as 5 oz. (roughly 90 to 150ml).
So, there are limits to what you can do with autofill systems, unless you want to alter them in a way that allows you to turn on and off the autofill. I believe Cannonfodder has done that with one machine. Alternatively, the poor man's way of doing this would be to drain a few oz. of water out the water wand each day, and most probably you will go back toward the lower level of the fill range.
I have now reduced the amount of water that will discharge through the water wand from a prior range of 21-26oz, to the current 16 to 19 oz. This is an obvious reduction but maybe not a huge one, but the shot temperature curves I have obtained with the lower fill level are tighter and more repeatable than before.
I will use a set of curves as a sort of "before and after" illustration, with "Random Walk-up Shots." Basically, as I define it, "random walk-up shots" are shots preceded by a standardized flush (50ml in the case of my machines) and measured at intervals of 10 minutes or longer in between shots. As a general practice in actual use of my machines, when my machines have been idling for long periods of time, say exceeding 4 hours, I generally do one of these 50 ml flushes and pull a blank shot, then wait a few minutes before pulling an actual shot, since the first shot from a long idle period tends to be too hot. I have done this when I have generated curves such as these also.
Here, on the rotary machine, are "before and after" random shot series at 232F boiler temperature. As with earlier observations on the (more easily adjusted) vibe machine, the shot temperature changes with boiler fill levels at the same temperature. Also note that the labeling of these graphs is a little confusing; the top one reflects a boiler fill level with the unmodified boiler probe set to the lowest point, and the bottom graph shows what happened after I bent the autofill probe as far as I could do so while still getting it inside the boiler, so there was a reduction in fill level from the top curves to the bottom ones:
vs.
I have other sets of curves that illustrate the same things, e.g. that the observed shot temperature seems to go up, and the curves become more repeatable and in a tighter range, as the boiler fill level is reduced. I will probably do a little more experimentation with this, to see if I can get the fill level even lower, although I believe that these curves demonstrate the basic point is valid in autofill systems also.
People who are seeking tight shot temperature control, who are using electronic temperature control of their boiler as a way of achieving this, should experiment with boiler fill levels. The shot temperatures you get are going to be related to the fill level, so even if you don't intentionally change the fill level, you should try to use the SAME fill level consistently. In a manual fill system this is easily done. With autofill it is harder, and may include regularly draining some water out of the boiler in order to get the autofill to reset the level at a consistent, probably lower, point.
ken
