Blind basket/disc for 49mm portafilter. DIY suggestions?
- dumpshot
I have an '81 Livietta with the 49mm group. Any suggestions on how to create or buy a blind basket for back flushing? I have only been able to find 58mm baskets and basket inserts. Cerini's sells a 54mm for the new Maximatics.
Thanks in advance. I have been looking for others' answers to this and haven't found anything.
Pete
Pete
LMWDP #484
- drgary
Cut some high temp sheet rubber to seal the bottom of your filter basket. Easy peasy!
LMWDP#308
LMWDP#308
- spiffy
If you can't source a high temp rubber sheet, something like this would work too: https://www.espressoparts.com/backflush ... ind-filter
It's made for 58mm, but you should be able to easily cut it down to size. I prefer these since I'm lazy and you can backflush without having to remove the basket.
- dumpshot (original poster)
Thanks, guys. Appreciate the feedback. As a lever guy, I thought would be something more complicated. I will get 'er going. The espresso parts disc looks good and is cheap.
Pete
Pete
LMWDP #484
Tried some freezer bag plastic last week for a gaggia classic that had not been backflushed for months, think that any reasonably temp resistant sof material will do, even low temp resistant rubber.drgary wrote:Cut some high temp sheet rubber to seal the bottom of your filter basket. Easy peasy!
The freer bag plastic did not work brilliantly, as it became a bit soft and I cut the circle too large in my haste, but the machine unclogged.
LMWDP #483
