mindless_fool wrote:thanks for all the info Randy. What would suggest looks to be for a plumbed in machine, but mine is a pour over tank based model. What i did was just fill the tank with RO water. But now that i know thats a bad idea, is just adding say half the tank with RO water and the other half with plain tap water going to be ok?
Mine is pour over as well! At least for now. I also have a VBM DS ( lever), and I ran the water system referred to in my two articles above to the machine in preparation for a plumbed in machine that should be here, soon...? Anyway, I terminated the 3/8" JG plumbing line with a 90 degree valve. I currently just use that like a hose nozzle and fill the reservoir that way. Very convenient!
As far as 50/50, it depends on the water... If you can hack into the Watts system, take a line from just in front of the RO membrane cartridge and put in a Tee... Like this:
The valve will allow you to mix just the right amount of filtered tap water in with the RO water. This keeps you from having to run straight tap water in your machine and your hardness test kit will let you adjust it, or get one of those inline TDS meters I referred to above.
Creating that add-on to your system with JG should not be difficult.
