Bezzera Elisse component leaking, help!
Postby agaudry on Sun Mar 29, 2009 4:05 am
bezzera elisse component leaking!! help with identifying problem please..
Water is coming out of component No.2 as itemised below. Any ideas - i can't afford an engineer to fix this but could do with a helping hand in the way of 'picking s'one's brains' about it and then 'hopefully' just changing a washer (gasket) of whichever component need replacement! Thanks in anticipation. I have a temp fix in place at present but want to sort it out properly. Thanks again Alan
The relevant pdf tech drawing is available at the bezzera site
http://www.bezzera.it/pdf/ELLISSE_GB.pdf
BEZZERA
Tav. 08
dal 1901
Dal 1901
POS DESCRIPTION
CODE
REFERENCE
01
OR GASKET 102 NBR 70SH ................................................................................................................................7496009 ............................-
02
STRAIGHT FITTING 1/8"G H20 OT
agaudry
Postby erics on Sun Mar 29, 2009 12:04 pm
The component that is leaking certainly APPEARS to be the mixing valve for the hot water dispensing system. The likely culprit is a broken o-ring (7496009) which serves to seal the "adjuster" (5263801) as it screws in/out of the fitting (5225208). Without trying to trace out your hydraulics, I would shut off the water supply to a cold machine and break out the wrenches.
Simply replacing the o-ring (7496009) MAY solve the problem but as long as you're in there, I would replace all three components. Lubricate the new o-ring with a light smear of food-safe grease (Dow-Corning 111) and seal the threads of the fitting (5225208) with a suitable thread sealant prior to installation.
Skål,
Eric S.
http://users.rcn.com/erics/
erics
Postby agaudry on Sun Mar 29, 2009 4:13 pm
erics - thanks so much for the post on this. I'll do as you suggest and post here again to let you know how it went. Thanks, alan
agaudry
Return to Espresso Machines
