www.veniacoffee.com: purveyors of specialty coffee and exceptional equipment
Bezzera BZ99 portafilter question
Postby AngerManagement on Wed Nov 16, 2011 11:21 pm
YEP... For some unknown reason (to me) there is two slots cut across the lip of the PF as provided with the new BZ99
For a blind it does not matter as no water in the bottom of the PF.
With coffee and a normal basket... The pressure is on top and the good oils flow through and out the spouts..
With a gauge attached to the spout and either a restricted flow or the spout blocked off then;
1: the water flows into the PF and then as pressure builds up in the PF.
2: The water flows all around the inside and the underside of the basket as the pressure builds.
3: It then finds these two slots and as an escape path and sprays water every where.
Needless to say trying to get a reading via a fitting from the spout with a standard BZ99 PF is a waste of time. Have also been unlucky as the other 5 PF I have come close but do not fit correctly. I guess I just have to keep trying.
But can any one provide an answer or a theory as to why the PF has these two slots cut into the lip ?
Ability is nothing without opportunity. - Napoleon Bonaparte
AngerManagement
Postby allon on Wed Nov 16, 2011 11:31 pm
AngerManagement wrote:Needless to say trying to get a reading via a fitting from the spout with a standard BZ99 PF is a waste of time. Have also been unlucky as the other 5 PF I have come close but do not fit correctly. I guess I just have to keep trying.
remove the basket and use the pressure gauge without a basket. It'll seat funny, but that's how to make it work.
(note - not sure about the slots; it might still be an issue, but it might work, depending on how it seals against the group gasket. I *THINK* mine has the slots too - I'll have to check; they might be to ease getting the basket out)
LMWDP #331
allon
Postby HB on Wed Nov 16, 2011 11:49 pm
AngerManagement wrote:But can any one provide an answer or a theory as to why the PF has these two slots cut into the lip ?
To allow air to enter under the lip and thereby avoid an occasional glub glub glub. Think of pouring water out of a plastic jug by turning it upside down versus turning it upside down and poking a hole in the bottom. The water will pour out more evenly in the latter case.
Postby AngerManagement on Thu Nov 17, 2011 4:38 am
Thanks Dan and allon...
There is some agreement re the slots and to act as a relief / vent... But if it was critical, one would expect to see it else where, thus why ?
And if it did make a difference to the cup, what not then market the feature. But could find nothing on it. Mind you google it not always able to find exactly what you want / ask for.
Allon, if you don't use a basket.... Then teh slots are deep enough that the lip would need to bite at least 4mm into the group seal...
I think I will just need to did out another 4 or 5 PF and try them all. ONE MUST FIT :oops:
Mark
AngerManagement
Postby HB on Thu Nov 17, 2011 8:25 am
AngerManagement wrote:There is some agreement re the slots and to act as a relief / vent... But if it was critical, one would expect to see it else where, thus why ?
Maybe it was considered important during the days of Robusta-laden bar blends that produced mountains of crema (?). IIRC, the older Rancilio commercial portafilters had a slot, but newer ones don't. *shrug*
Return to Espresso Machines
