JonR10 wrote:JonR10 wrote:
TerryZ was uncharacteristically unhelpful on the phone today. <snip> He did say if I order one and put in the notes that I need the adapter for my Wega that they would include the fitting for free.
OK, I apologize for this remark. I had called Terry at 5 PM his time (7 PM my time), he was at the end of his day, his server was down and he couldn't do anything to help me. I also was at the end of my day (still at work at 7 PM) and tired and frustrated about this whole deal.
Terry called me back today and was back to his usual helpful self. We talked about the options and pros/cons and I decided to go with the Sirai because it will probably last ALOT longer than these other devices and I have plenty of space.
The Barksdale device in my machine seems destined to fail and I need a more permanent solution. The Barksdale is sitting in a very hot environment (no boiler insulation), it's at the limit of it's adjustment, it's regulating water above it's rated temperature, and it has already drifted to and fro on the setting (probably due to heat exposure), the thumbwheel already has a couple of broken spokes because it's so tight and so hot that I need to use a Channel Locks pliers to adjust it.
So anyway - thanks to TerryZ I have a new Sirai AND the correct adapter fitting on the way.
Now, if anyone can find me a source for MALE BSPP adapters I would love to know about it.
Sirai's are bulletproof, and if you get the ones with 3 contacts they'll last as long as your machine.
I have no personal experience with the Barksdale, however, it appears from all that I have heard to be a small volume custom made product or custom modification of another product, and as such will have all the disadvantages of something that has not withstood the rigorous testing of an "off the shelf" standard machine part. Even if they don't test the off the shelf parts much before they release them into the channel, they end up being used so much that any flaws become apparent and if they are made to a high standard (as is the Sirai, not true of the mater or the CEME) they will be modified if need be down the line to ensure that what you are getting is at least decent.
You can arguably make the same statement about PIDs; the controllers, at least those used commonly in industry like the Fuji and some others, and SSRs, which are likewise ubiquitous, have stood the test of time in many applications and are regarded by people who use them in critical applications to be very reliable. If one reads the coffee website forums and alt.coffee, one does not commonly see threads entitled "my Fuji bit the dust," or "my SSR failed in the 'on' position." The industrial applications in which these common-as-dirt parts are used, if anything, stress them more than we mere mortals do in our espresso machines.
So, in my opinion at least, a PID installation is probably going to be as bulletproof as anything else you might put into an espresso machine for temperature control. It will also offer something that other options do not; the ability to quickly change shot temperatures without developing a complicated flushing routine, on a heat exchanger. As an example, with the SO Harrar Horse I've been using lately, I typically set the boiler at 232.5F when I anticipate making a milk drink and at 230.5 when I'm making a straight shot. I can do this with very little advance planning. 230.5F will give me a shot of about 199F, and 232.5F a little higher. The main difference is that I can froth milk easily at 232.5F and can't do so at 230.5F BUT, 230.5F gives me a more reliable sub-200F degree shot, which matters more, in my opinion at least, for straight shots. So, I can do the switchover that is near and dear to the hearts of most home baristas, e.g. between milk drinks and straight shots with the same beans, and I can do it painlessly.
Trying to do this with a pstat, any pstat, will involve (at minimum) removing a machine side panel, getting out a screwdriver, and futzing around for several minutes. This is to say you won't do it, so you will be "stuck" with whatever setting you decide upon for the pstat as an acceptable compromise.
ken
