If you want to get very picky, you could take a pair of precision calipers and measure the basket. Then get one custom turned, I had to do that for my Gaggia Factory lever machine. I tried to use a plastic tamper that I cut down to size, it worked until my stainless tamper arrived. Use the correct tool for the job and life is so much nicer, and much tastier...
Dan did a bang-up job on his
HX article. When I got my HX machine, I was a bit lost. This is the best article I have seen, it helped me understand what was going on and shortened my learning curve.
I have a different machine (Isomac millennium) but I run my boiler at 1.3 top and 1.1 at the bottom. I do a lot of frothing so I prefer the higher steam output. Downside, my recovery is very short. I dose my PF and tamp, then flush into my cup until the hissing subsides plus another three seconds. Lock the PF in, take my now blazing hot cup and pour it into the sink, stick it under the spout and flip the handle, about 10 seconds from flush to go. Some espresso blends like hotter temps, other work well in cooler water, but the first order of business is consistency, then work on variations.
