www.veniacoffee.com: purveyors of specialty coffee and exceptional equipment
Baratza Vario + Crossland CC1 = perfect shot - Page 2
Postby mikek753 on Mon Jan 16, 2012 3:29 pm
hi,
I switched to another beans and got huge improvement :shock:
The beans were rested for 14 hours - it's Milano blend
I have to grind coarser those beans than SO
Please, comment on my extractions
http://www.youtube.com/watch?v=MoqkmTVdhXQ
http://www.youtube.com/watch?v=F8fT2we2Ve4
if any interest this is how I roasted those beans
http://www.youtube.com/watch?v=i0vd80dp9XI
your guidance for me are very welcome :)
Best Regards.
Mike.
mikek753
Postby dman777 on Wed Jan 18, 2012 8:01 am
Those are excellent shots. I would of bought that machine if it looked cooler aesthetically. Are those stock baskets you used?
dman777
Postby boar_d_laze on Wed Jan 18, 2012 9:34 am
Evaluate every pull by tasting. Naked pfs are only learning aids -- training wheels if you will. You can learn a lot with your eyes, but perfection is in the cup and not in the appearance of an extraction. Try and correlate the appearance of the pull with the taste and bring what you can from the observations to your dosing and distribution techniques.
If Dick tells you that you're overly fine-tuning your dosing, you can trust him. It was the first thing I noticed as well, but I'm not the inveterate and critical measurer he is.
Even better is the advice to use older beans. While you got a fairly pretty pull, it's very unlikely you approached anything like a "perfect shot" with 16 hour post roast beans. How can you taste past the need for them to rest in order to evaluate your technique in a real context?
If this seems like scolding, I apologize. But I think your next big step in espresso making is not what you're doing, but in keeping sight of your goal and using the most powerful methods and tests (taste!) to achieve it.
Hope this helps,
BDL
boar_d_laze
Postby mikek753 on Thu Jan 19, 2012 2:47 am
dman777 wrote:Those are excellent shots. I would of bought that machine if it looked cooler aesthetically. Are those stock baskets you used?
hello,
The CC1 doesn't come with bottomless portafilter, but with normal PF and the bucket is the stock 58mm.
Best Regards.
Mike.
mikek753
Postby mikek753 on Thu Jan 19, 2012 2:51 am
boar_d_laze wrote:Even better is the advice to use older beans. While you got a fairly pretty pull, it's very unlikely you approached anything like a "perfect shot" with 16 hour post roast beans. How can you taste past the need for them to rest in order to evaluate your technique in a real context?
Hope this helps,
BDL
hello,
yes, sure it helps me. This is why I asked for the feedback
And yes, I see some difference with 2 days old beans.
But, new roasted beans smells so good ... hard to resist
Thanks.
Best Regards.
Mike.
mikek753
Previous
Return to Espresso Machines
