buzzon wrote:I see another valve directly in the middle and upper back of the unit. It looks like an OPV (expansion valve); what is that? It can be adjusted but I didn't want to touch it without knowing more.
... My pump pressure varies from 130, idle, to 190 PSI when drawing a shot. The boiler pressure stays at 1.5 bars all the time, idle or drawing.
Take a picture of the other valve and someone should be able to clarify what the discrete valve is. Usually a rotary pump machine relies upon the integral bypass adjustment to set pressure. And vibratory pump machines have a separate OPV instead. But some machines will have a rotary pump/bypass adjustment and an OPV. If it is an OPV, then you would adjust your bypass screw to get 130 psi during a shot & set the OPV somewhat higher, as a secondary relief. Or the valve you are describing may be something different. I wouldn't adjust it until you confirm what the valve is.
As to your pump pressure, at idle the pump will produce no pressure. So depending on how your machine is configured the gauge would then read zero or the water line pressure. So 130 psi when the pump is idle, sounds like your water line pressure is 130 psi. That is a high pressure to start with, most people have a line pressure about half that. So you really need a water pressure regulator to drop that down to something like 30 - 60 psi. Then adjust your bypass screw for 130 psi during a shot.
