Merry Christmas y'all!
I have a 1999 Astoria Argenta SAE/2N.
So far I've hooked up power and plumbed it in. My manual boiler fill works. My autofill sensor works, too. When the boiler gets below a certain level, my rotary pump kicks on.
However, when that happens the boiler does not fill. Only when I press the manual fill button (whether the pump is on or not) will the boiler actually refill.
Likewise, when I go to pull a shot, no water from the grouphead.
Thoughts? Even though my pump is running, how could I test it to make sure it is functioning correctly?
Boiler refill solenoid is clean. Haven't checked group solenoids yet.
Apart from this issue, the machine is fully functioning. Comes up to heat, pressure gauge works as intended, steam wands and hot water tap are perfect. Just no water from groupheads and no water into the boiler when autofilling.
I will greatly appreciate any thoughts you have. Thanks,
Kevin
