CRCasey wrote:Are you going to stick with the rainbow speckle on black exterior?
I don't really like it... and I've considered keeping it as just the frame... but probably going to put them on...
I would hate to spray paint the panels.. they'd come out like crap... sand blasting and powdercoating is an option, but would probably be fairly expensive.. maybe for a future project
Ok so now some problems...
1. Hooked up electricity and found a burnt fuse.. why does this thing even have a fuse? it's only for the motor and is 8A... probably to prevent overheating or something?
So Jumped it temporarily... Any thoughts on using an automotive fuse in the future?
2. After jumping fuse, motor runs, pump turns but boiler wasnt filling up [dont worry heating element disconnected]
Disconnected water pipe from flowmeter and it was only flowing w. line pressure... looks like pump was no good.
Put a spare pump I had on and now we have pressure.. but no boiler filling...
I kept taking things apart up the water path until I came to the solenoid for auto-fill. Seems there was blockage so bad I had to nearly hammer in a needle to break up the debris...
So it probably works now... but didnt have time to test it.
Now it's sitting in my room waiting until the next time I'm home from med school
And the worst problem was a voltage leak somewhere.
Between the chassis and the kitchen sink....
Tested it and it looks like 50V... NOT GOOD
