Hi. I need some feedback from someone who has experience with the Astoria Argenta 1 group JUN machines.
What is the default amount of water flow you get out of the machine?
I get 40-50ml per 10 seconds - max. Is that normal?
For reference, It's a 1996 110 volt machine. Internal Procon pump. I have removed and checked the pump, and it seems fine. Looks stock all the way. I have taken the group apart, and it's totally clean. Gicluer is fine. No signs of scale anywhere. If I remove the bell entirely, I still get the 40-50 ml per 10sec flow - max.
It is plumbed behind a watts regulator set to ~35psi. The stock pressure gauge is shot, but I have set the brew pressure to about 9bars w/a pf gauge.
The shots it pulls are gorgeous in most every way. It's just there is pretty much a full 10 seconds before first beading due to the low flow rate and ramp up.
Thanks much for your reply.
