Arduino-based espresso machine controller [WIP] - Page 4
Postby napierzaza on Wed Feb 09, 2011 10:14 pm
Yes, I've decided on C. But what I mean is that I'm having trouble figuring out how to start a project or how to compile. Some headway already.
napierzaza
Postby Carneiro on Thu Feb 10, 2011 1:10 pm
Nathan, what embedded platform are you using? And how about the Linux distribution?
Márcio.
Carneiro
Postby napierzaza on Thu Feb 10, 2011 1:45 pm
Hey,
I'm trying to use OpenWRT as the platform. It's an Atheros based router called the Meraki Mini. It has but easy GPIO pins that I can hook a daughterboard too.
I'm just a little unsure how to interface with the GPIOs, though there is information in regards to setting them up for i2c.
Damn it, only now I realize that Bourbon isn't PID. Oh well, will try with Kona and see.
napierzaza
Postby aindfan on Wed Feb 16, 2011 2:06 pm
An update on my progress: I am getting up to speed on Eagle and starting to work on a board layout based on the TC4 design. This will include all of the TC4 components but add two more SSR drivers and integrate the LCD screen driver on the same board. In addition, I am in the process of putting together my probe setup, which I will describe in my rebuild thread.
Thanks again to the TC4 creators!
Dan Fainstein
LMWDP #203
PSA: Have you descaled lately?
aindfan
Postby randytsuch on Wed Feb 16, 2011 4:28 pm
aindfan wrote:An update on my progress: I am getting up to speed on Eagle and starting to work on a board layout based on the TC4 design. This will include all of the TC4 components but add two more SSR drivers and integrate the LCD screen driver on the same board. In addition, I am in the process of putting together my probe setup, which I will describe in my rebuild thread.
So you're adding the I2C port expander for the LCD?
If so, you could also use the other 1/2 of it for push button inputs.
To get all of this on one board, it would have to exceed the standard Arduino shield size, is it going to be the size of a Mega shield? Regardless, sounds like a nice board with a lot of features. It would also work well with my roaster PID program.
Randy
randytsuch
Postby aindfan on Wed Feb 16, 2011 5:19 pm
Randy, I will be using an Arduino Mega2560 and I intend to bring up all of its pins in my shield design using the stackable headers (you know, just in case :D ). Now that my homeroasters.org account has been activated, I'll continue the discussion in the TC4 thread due to my proximity to that project.
Dan Fainstein
LMWDP #203
aindfan
Postby JimG on Tue Mar 01, 2011 6:56 pm
JimG wrote:When I have a new set of bare boards in hand, I'll post an update here. Then you can use this link to order.
A quick heads up: the new TC4 version 4.00 boards have been ordered and should arrive no later than mid-March. I'll start taking orders as soon as I've tested the new boards.
Jim
JimG
Postby aindfan on Tue Mar 01, 2011 11:05 pm
Jim, can you comment on the changes from 3.00 to 4.00, if any?
Thanks!
EDIT: I see that the description is posted here. Thanks again!
Dan Fainstein
LMWDP #203
aindfan
Previous
Return to Espresso Machines
