by tombrazier on Sun Apr 10, 2011 5:15 pm
Just found this conversation when googling to see whether anyone else was doing the same as what I'm playing with.
I have a Gaggia Baby Class on which I'm controlling power to the pump by energising the coil for only part of each mains half-cycle. So a slightly different approach. I suspect your response curve is much more linear than mine, but mine has a greater resolution and, I imagine, a smoother flow.
Anyway, I thought I'd report that combined with a flow meter I'm now experimenting with PID controlling the flow of the entire extraction. Which means I get the same rate of flow regardless of grind and tamp, and also means I don't need an adjustable OPV. (The Baby Class's OPV is hard-wired to 11Bar as far as I can tell).
Results are variable so far - it's beginning to look like I need a different brew temperature now that I've reduced the flow rate. But I did get a very fine shot this morning, so I'm hopeful.
