miKe mcKoffee wrote:Seems like a rash of ailing Bric's! This one was weird. Went to pull a pre-shot cooling flush, hissing water started to flow like normal then I heard a pop and water flow stopped. Out of the group that is, continued inside the machine. When I heard the pop almost immediately closed the lever turning off the pump but of course line pressure continued forcing water out until it hit my "water leak sensor" which tripped the water line closed. Turns out the fitting on the pump water out had simply "sheared" off! Not under shot pressure just flushing.
This is the second water fitting to go in 2 years 11 months. Last summer a tee fitting spontaneously developed a crack and started leaking severely. (Hence added the water leak sensor, good idea any direct plumbed machine to avoid floods.) Failures I expect, but two simple water line fittings? Terry nor anyone else at ESPN have ever seen this line of fittings.
Fortunately happened a day I took off from the Cafe AND in time to make the 5 hour 224 mile round trip to ESPN. Bric' back up.
If anyone asked I'd no longer recommend the Bricoletta line. Water fittings should not spontaneously crack or break off under normal use in such a relatively short period of less than 3 years. One I thought bad luck, two bad quality control and cheap fittings IMO.
mike mcKoffee wrote:If anyone asked I'd no longer recommend the Bricoletta line.
