by Beezer on Sun Aug 14, 2011 4:34 pm
I descaled my Quickmill Anita yesterday and everything seemed to go fine, but there was still some sourness from the descaling solution coming through in the flavor of the espresso, so today I flushed the boiler out again. I turned off the machine and used the hot water tap to drain the boiler, tipping the machine up a bit to get as much water out as possible. Then I turned on the machine and let the boiler refill. The machine came up to pressure normally, and the boiler stabilized at about 1.2 bar as usual. But after a couple of minutes the GFI popped and turned the power off.
I took the shell off and checked for obvious problems like leaks or short circuits, but didn't see anything out of the ordinary. Then I tried turning the machine on again, and once again it came up to pressure normally, but then popped the GFI after a couple of minutes. So it appears that something is short circuiting inside the machine. I'm hoping I didn't damage the heating element by draining the boiler too much, but that would probably explain the GFI popping.
Anyone have any suggestions?
Lock and load!
