Andreja Premium - brew pressure gauge high at rest?
Postby irrelevancy on Sun Aug 21, 2011 2:20 am
Hi all
So I've got my new andreja premium, and have a question about the pressure gauge reading.
The boiler pressure gauge is fine - reading about 1.2 once the machine has heated up.
I'm a bit confused about the brew pressure gauge though - once heated up, this actually reads a baseline 4.0 bars (but goes up to 10 bars during the extraction). I thought that at baseline the pressure gauge is meant to read 0 - or am I misunderstanding things?
Once I release the pressure, the gauge goes down slightly, to around 9 bars (and there's the foosh of water out the pressure release pipe), but then stays there. If I then run the pump without a PF locked in, the pressure drops a little to 4 bars, but doesn't go below that. Plus I get water going out through the pressure release pipe (even though there's nothing in the group head!) Is something wrong?
P/S: a video demonstrating it is below
Thanks
Sing
irrelevancy
Postby erics on Sun Aug 21, 2011 8:23 am
The reading on the brew pressure gage is meaningless unless the pump is operating.
If you are simply flushing water through the heat exchanger, the typical presssure is AROUND 4.0 bar. This pressure is caused by the flow restriction "offered up" (mainly) by the 0.70 mm gicleur in the grouphead.
What you are calling the "pressure release pipe" is the exhaust or drain portion of the grouphead. There should be NO FLOW from this area WHILE flushing or brewing. When you return the brew lever to the down or off position, you mechanically open this valve and any water in the preinfusion chamber will drain out.
Skål,
Eric S.
http://users.rcn.com/erics/
erics
Postby HB on Sun Aug 21, 2011 9:07 am
As Eric noted, the brew pressure gauge reading is relevant when the pump is running, but otherwise isn't useful. I elaborated on this point in Brew pressure rising during warm up:
HB wrote:As water heats, it expands; since a boiler/heat exchanger is a closed system, the pressure rises. It's nothing to worry about since the expansion valve opens to relieve pressure as required. The expansion valve is typically set to open around 12 bar for rotary pump espresso machines since they have their own bypass valve to regulate brew pressure. For vibratory pump espresso machines, the expansion valve (traditionally called an over-pressure valve in this context) is set to open at the desired maximum brew pressure, usually around 9 bar.
In a nutshell, the brew gauge reading should fall to 0 when you lift the lever and then rise to the pump's set point. When idle, the reading is the pressure in the heat exchanger due to water expansion.
Postby cannonfodder on Mon Aug 22, 2011 11:31 am
Unless you have a plumbed in machine, then you get the static line pressure from your mains on the brew gauge. Most vibe pump machines read about a bar to 1.5 bars high on the gauge compared to the actual group head pressure so if you are getting 10 bars during an extraction, it is probably closer to 8.5-9 bar at the group head.
cannonfodder
Return to Espresso Machines
