The question I have is about boiler pressure hunting. The boiler loses pressure very quickly in my opinion. From the time the pressure reaches the top of the band (~1.1 - 1.2 bar) and the heater shuts off, it takes only 3.5 minutes for the pressure to drop to the bottom of the band (~0.75 - 0.8 bar), switching the heater back on. Approximately 15 seconds to "heat" to 1.1 bar then repeat. You can actually watch the pressure gauge drop.
Is this rate of pressure/temperature loss normal?
I expect that a sealed and insulated boiler should hold pressure/temperature way longer. There are no obvious leaks, puddles or steam clouds. I have not made any adjustments to the factory settings.
Further to this, my dead band seem too wide, looking in the little access hole I can see that my Andreja is equipped with a Mater Pressure Stat. Can the dead band be adjusted by the "Home Barista"?
Any information would be greately appreciated.
Thanks, John
