by thaxton on Sat Jan 24, 2009 9:18 am
You can adjust the boiler pressure (an easily accessible adjusting screw at the top of the pressurestat) but think twice before you do it. 0.9 is the minimum recommended pressure, however in HX machines the problem is usually too high temperature. The only reason to increase the boiler pressure is that it makes it easier to froth milk.
If you like your espresso and manage to foam milk nicely, leave the parameters unchanged.
