Aluminum boiler in Astoria Argenta - really?
Guys, I'm scratching my head on this one.
Did Astoria ever use aluminum boilers? I can't find any record of that, but when I opened my Astoria Argenta 2-group project machine to see how big a project it's going to be, I was surprised to see a boiler that doesn't look like copper at all. It does not attract a magnet, so it's not stainless steel.
Pictures follow:
Pictures follow:
I have no idea, but all stainless steel is not magnetic or at least enough to detect by placing a magnet on it.
- NightFlight
I agree with jonr, it does look like stainless; and stainless is non magnetic.
http://www.scientificamerican.com/artic ... s-work-on/
Some is, it depends on a variety of factors. As I understand it all of it technically is, but not enough for practical use.
Oops! Well, that's embarrassing but I googled it and indeed, many types of stainless steel do not attract a magnet. I learn something new every day - thanks!
Since the machine needs a teardown and rebuild, and since stainless steel is about 3x the density of aluminum, we should be able to determine for sure which metal makes up the boiler by measuring how much water the boiler components displace, then weighing them to calculate the density.
Thanks again!
Thanks again!
- sweaner
I suspect that you will know as soon as you pick up the boiler!
Scott
LMWDP #248
LMWDP #248
- drgary
I learned about magnetic and non-magnetic stainless when we moved to a new home equipped with an induction range and without access to natural gas.* Since it heats cookware via magnetic fields, we had to ditch a lot of our old stuff and buy a new set. If that were aluminum you'd probably see corrosion somewhere.
* Sure, we could get propane, but I've learned to use the range just fine.
LMWDP#308
LMWDP#308
Interesting read about it here: Why don't magnets work on some stainless steels?
______________
Alex
Home-Barista.com makes me want to buy expensive stuff.
Alex
