www.baratza.com: skilled in the art of grinding
Alex Duetto beeping
Postby Lee 66 on Sat Feb 28, 2009 10:57 am
Hi,
Just got my new Duetto home on power up I get is a beeping tone anyone know what this is ?
Regards Lee
Lee 66
Postby JimG on Sat Feb 28, 2009 12:37 pm
Lee 66 wrote:Hi,
Regards Lee
Low water in the reservoir?
JimG
Postby zin1953 on Sat Feb 28, 2009 12:50 pm
Well, that would be my guess . . .
zin1953
Postby akallio on Sat Feb 28, 2009 12:55 pm
It means there's not enough water in the reservoir. If it is full, then the tank might be misaligned. Try moving it a bit and check that the switch below it gets switched properly.
akallio
Postby Lee 66 on Sat Feb 28, 2009 4:10 pm
Hello,
Thanks for the response, crisis over it wasn't low water but you sent me the right direction. It was a few pieces of polystyrene packing under the plate the water tank sits on preventing the plate from being depressed there must be a read switch /sensor underneath the plate. No more beeping now working OK.
Cheers Lee :P
Lee 66
Postby aglazen on Thu Apr 09, 2009 6:45 pm
I just got my new machine today---had the same beeping, realized that first time you fill, most of it goes in to the boiler, so you need to fill the reservoir again.
My problem is---the steam pressure feels very low, takes forever to steam a small amount of milk.
The bottom gauge of the machine shows nothing, the top shows 1.2. Is the black steam switch on the side illuminated when on? (mine is not).
Any idea one what might be going on??
aglazen
Postby jthor on Thu Apr 09, 2009 9:16 pm
The steam switch on the right should go between green and red, let it warm up
jthor
Return to Espresso Machines
