If I hold my brew button just so, I get the solenoid actuated without the pump, giving me (unreliable, depending on how carefully I press) preinfusion. I thought about automating it with some kind of time-delay switch, but was unsure of which to use or exactly how it should be connected/powered.
I have thought about this, and my ideal would be a big lever on the side of the machine, connected to a bypass valve similar to the one on the pump. Up would be full bypass, down would be no bypass (9 bar), allowing me to control the pressure of the entire operation
