Adding an OPV to Olympia Maximatic
I'm guessing that finding the correct OPV might be the hardest part?
Or maybe routing the return water?
I have the portafilter gauge mostly put together; I just need a compression fitting which I can pick up tomorrow.
Then if the pressure is high, I will want to dial it down.
I'm not sure what I need to know to source an appropriate OPV; any advice will be appreciated.
Susan
Susan
- HB
- Admin
Contact Johnny at Cerini Coffee & Gifts, he has everything you need.
Johnny suggests NOT adding an OPV but replacing the pump with a "new" pump which the new Maximatics are being equipped with.
I just tested the pressure with the gauge and it's definitely more than 10 bar.
Seems to me an OPV gives you the option of changing the pressure whereas a new pump gives you a better but "fixed" pressure.
Hmmm...decisions decisions decisions....
- another_jim
I added an OPV to the Elektra Semi using one sold by Chris Coffee, and short circuiting the return water into the hose that fed the pump via a tee. The set up worked fine for adjustung pressure, but it was very noisy. For the Semi, it made almost no difference in the taste (although adjusting the OPV on an E61 made a huge difference). So my two cents is that it's worth a try, but that it may be more noise than good shots.SJM wrote:I'm guessing that finding the correct OPV might be the hardest part?
Jim Schulman
- algue
Jim,
as you know I have a semi and OPV is something I'm thinking about.
what do you mean exactly with the word "noisy"?
and, how can the pressure be regulated without a gauge?
alberto
alberto
There's a thread about adding an OPV to a Maximatic Olympia Maximatic. Stick to old or change to new? that might be helpful.
That is an excellent thread.
It is part of how I got to this point....)
