theCoffer wrote:Hello, I have been reading a lot of old threads about pressure and how important is not to exceed too much the 9 bar mark. Well, what I would like to know is the following:
Parting from the following premises:
- The puck flow resistance increases through the brew
- If the pressure in the water circuit increases, so does the brew flow
- The 9 bars that push against the puck are the natural generated pressure in a water circuit which's only exit is the puck and which has to exit at +o- 2ml/sec
- During the brew, as the puck flow resistance increases, so must the water circuit pressure in order to maintain the brew flow-rate of aprox. 2ml/s
Hi Martin. Interesting post, but all these points are debatable:
- As extraction proceeds, solids are removed from the puck. Resistance to flow tends to decrease rather than increase towards the end of the pour.
- Somewhat surprisingly, experiments by folks like Andy Schechter indicate that flow rates are maximal around 9 bar, and decrease with both lower and higher pressure.
- The "natural" pressure of 9 bars may be correct for a normale double flowing at 2ml/sec, but does not hold true for all pours (e.g., ristrettos).
- Again, flow resistance decreases as solids are extracted from the puck. There is no need to increase pressure to maintain flow; quite the contrary. Lever fans glory in the decreasing pressure profile of their machines.
theCoffer wrote:What I don't understand is:
How is it that adjusting the OPV could in any-way improve the shots quality without affecting the amout of coffee produced??
The OPV sets a limit on the maximum pressure, generally agreed to be optimal at around 9 bar. For normale doubles, this is not much of an issue. But ristretto pours can result in higher pressures if not limited by an OPV.
