Dickwayne wrote:I'm still super new to wiring and need help.
Welcome to Home Barista. How did you end up with an 380 volt European machine? I don't want to be unhelpful, but when you describe yourself as "super new to wiring", I don't think that you should be screwing around with this. You need on site help from someone with electrical experience. This is just too dangerous for someone without electrical experience and you could damage your machine, start a fire or worse. It would be difficult and time consuming for someone at a distance to safely guide you in this.
It sounds like you have a machine that is wired for 380 VAC, 50Hz, 3-phase power. As your location reads Arizona, your house should have 120 VAC, 60Hz, single phase (and possibly 240 VAC, 60Hz, single phase). A purely resistive heating element might be wired into a high amperage circuit in your home. But someone needs to investigate the wiring inside your machine (electronic design, solenoid, motor voltages, etc) to see what needs to be done.
It could easily cost you $500 - $1000 to convert your machine. Either with a combination of replacing internal components and rewiring. Or by running a dryer/stove type circuit into your kitchen, then using a pricey variable frequency drive + some creative wiring. Most electricians will have no experience with this type of project. So it's not impossible, but depending on the machines' construction it may be
very expensive to wire into your home.
