2-way solenoid vs check valve on plumb-in
I'm planning to plumb in my BZ02 and outboard the pump ala Dan's setup below. Would a John Guest check valve work as well as the 2-way solenoid in this case? Chris coffee's plumb kits also include the solenoid so it made me wonder if there was a particular reason to use the more expensive solenoid.
Thanks!
Thanks!
Ryan
- 4000ft
I dont think either is required, the machine has a check valve between the HX and the pump and a solenoid between the boiler and pump, and a vibe pump doesnt allow backflow in my experience.
Thanks for the reply. I'll also have a check valve where I tee off the mains, so I would think that and the ones within the machine would be good enough too.
Ryan
- cannonfodder
A check valve and solenoid are very different things and not interchangeable. A check valve just keeps pressure from back feeding into the public water system if there is a drop in city water pressure. It is required by most plumbing codes (if you do it code). A machine with a vibe pump is not designed for positive pressure from a mains connection. If you just plumb in a water line to the vibe pump you will end up with water running out of your group or 3-way valve. The solenoid blocks the water pressure and flow from the mains until you activate the pump. Yes you need it is the short answer.
- 4000ft
Only if theres a problem with the 3-waycannonfodder wrote:If you just plumb in a water line to the vibe pump you will end up with water running out of your group or 3-way valve.
