akabe wrote:can somebody confirm that the seals available will fit this model. ( it looks different from frank's though it does look similar to the zodiac one) . // my big concern now is the state of the cylinder ,( posting higher rez pictures ) . it is pretty corroded . will it leak ? guess the best thing to do would be to order new seals and actually try it out. ideally i'd like to intervene as little as possible on the machine. so, should i try it as it is and if it doesn't leak just keep it like this ? should i just sand it as smooth as possible? this would make the corroded end a bit wider than the rest of the cylinder . it actually already is a bit wider . would the rubber seal be able to handle this difference in width and is it a sensible thing to do ? conversly , if i machined the cylinder even by a fraction of a milimiter would the seal still work or will it just fall through ? what sort of tolerance do these things have . Evidently you can only really answer these questions by trying out different things but i'm wondering if anyone has had any experience with this.
...snip...
does anybody have or know any pictures of the heater plate and the group body opened, separated. this is one of those times i wish for x-ray vision . i'm particularly curious about the profile of the two parts where they are joined. not necessarily this generation and probably an urania, president etc would be equally useful. i'm wondering if it makes sense trying to knock the cotter pin out which could probably be done from the inside with the right L-shaped tool , otherwise it could be drilled out.
Alin,
If you don't need to take the plate off the back of the group, why mess with the cotter pin? Is disassembly needed? On my Urania there is no separate plate on the back of the group.
The corrosion on the cylinder is pretty bad. I'll begin by saying that I've not tried this. I'd avoid sanding the cylinder though unless you were planning on polishing it afterwards because a sanded finish would be hard on the seals. There is some tolerance in the seals but you would need to suck it and see. Personally I'd try the replacement seals without working on the cylinder, and if they don't work, see of you can smooth the bore a bit with some wet and dry and then some polishing. Machining the bore would be a last resort and whether you needed a different (non-standard) seal. or could still use the stock ones would be a matter of experiment.
Greg
