malachi wrote:I think evaluating from taste of espresso is confusing / not worthwhile.
I agree. I don't actually know now why I spent all that time yammering on about a poor extraction. You had originally said that careful flavor detection is near impossible with good, consistent espresso.
Therefore, I used the last bit of the bag in a cupping. I would like to note that the coffee is at the end of it's life (roasted 1/29), and that I have never actually cupped a coffee before. Also, espresso blends taste super weird to me when not brewed as espresso - this one in particular seemed very unbalanced.
I used about 7g of coffee with about 6 oz of water. The water was close to 200 degrees and I let it steep for 4 minutes. I tasted it using a tablespoon with the customary slurping technique but sampled it several times as it cooled.
Cupping Notes:I couldn't decide at all what it reminded me of. It tasted faintly sweet, like brown sugar, but I couldn't pick out any other defining characteristics. It wasn't at all bitter, but it seemed dry, like a wine. As it cooled a little I started thinking that it tasted woody. However, I was getting some grinds in my mouth, which add an element of cellulose. At a medium temperature it had caramel, and maaaybe just a hint of chocolate, with a nice finish. When it was cooler it tasted weird, like sucking on bitter black tea leaves.
I think I was picking up some woody / bitter notes, but I
wanted to taste those. The whole cupping seemed inconclusive to me. I didn't trust my impartiality. Therefore I decided to brew it again in an Aeropress, which is how I brew all my coffee that isn't espresso based. I'm more accustomed to this method, with better reference points.
___________________________________________________________________________________________
I used 1 1/2 Aeropress scoops with 2 1/2 markings of water. Slow saturation, 12 seconds of stirring, about 16 total seconds of brewing with 174 degree water. Then I topped off the 10oz mug with hot water. I just drank the mug as it cooled.
Aeropress NotesDefinitely a much rounder caramel at first, with a lot more sweetness. I noticed a quiet smoky flavor, slightly woody again. A little later it had a bad aftertaste of lime zest with a good after-aftertaste of sugar (this was a bizarre experience). Then came the bitter tea phase, but this time with a flavor pretty similar to my "wood chip" description. At a cooler temperature it distinctly tasted of dried/candied fruit (like oranges or bergamot). At a cold temperature it tasted like a heavily watered-down medium-quality scotch... not that I would know what scotch tastes like...
All in all I'm pretty convinced that there are some woody, bitter, woodchippy, balsa, whatever flavors in the blend. They come across similar to tea bitters, but with slightly different timbres than lean towards sap. They are not very strong, and I was hunting for them, but they were strong enough to not be imagined.
I'm not sure if this is a regular feature of this blend, but I would bet it is a slight flavor defect in this particular batch. It's not a big deal either way. I think I've been tasting this flavors in lattes with over extraction. I assume the above described flavors would be intensified with over extraction. As explained verbosely before, channeling is a common problem for me. I don't think it is brew temperature related, because I made a shot that was harsh in an entirely different way with a higher temperature.
That's my story and I'm sticking to it!
Any comments?
