Vacuum storage harmful? - Page 6
- aecletec
I haven't seen any in my area, online may be my best bet... Combining with inert gas might be pretty effective!
I found an estimated 4-6.4atm quoted in this paper but the source papers are lost in wherever the reference list is.
https://atrium.lib.uoguelph.ca/xmlui/bi ... sequence=2
While oversimplifying the issue, I'd imagine any increase in pressure would help but the actual effect...?
Just wanted to chime in here....
I've been using the 'vacuum seal' method for a couple years now (FoodSaver). I try and buy beans as fresh as possible and seal/freeze immediately. After being stored (even for weeks), beans pulled from the freezer and put in a mason jar will continue to de-gas as if fresh. I have been very impressed with this method.
That being said, the only ill effect I've noticed (which I may/may not be imagining) is that previously frozen beans seem to deteriorate quicker (but not quickly enough that they aren't gone before becoming that stale!).
- jesse (original poster)
I'm going to order a bottle of Bloxygen, which is apparently 100% argon, whereas the stuff marketed specifically for wine preservation all seems to be a mixture of various inert gases.
- aecletec
I'm using winesaver because it's locally available, it's argon - so I lucked out.
I received my tennis ball savers today, looking forward to seeing if there's any noticeable effect.
- aecletec
Problems I can foresee include damage to the container from degassing pressure build up or maybe absorption of plastic smell. Can use a snap lock bag for the smell, perhaps. Might be awkward with the inert gas, though.
Been doing the same thing, vacuum seal with a foodsaver and freeze, for years. I have not noticed the coffee deteriorating any faster. I note the days post roast on the bag and it acts like I would expect when I go to use it. When using part of a two pound bag fresh and part after freezing there isn't a discernable difference. I actually left (lost) a couple bags of coffee in the freezer for over a year and it was fine when I used it. Tasted great, normal crema production, and had normal aging/staling time in the hopper. Just a normal freezer on the lowest setting btw.mixedup wrote:Just wanted to chime in here....
- aecletec
When you're talk
Thanks for your impressions. What kind of beans were you using? Any particular flavour profiles?Zendel wrote:Tasted great, normal crema production, and had normal aging/staling time in the hopper.
- nickw
I also freeze beans in small canning jars (enough for 5 coffees) so 1-3 days worth.
When I pull them from the freezer I let them defrost at room temperature. I like to wait 12hrs before opening, as to allow any moisture condensing inside the jar a chance to equalize with the beans before opening.
It believe it was Belle Espresso from Klatch and Ambrosia from Caffe Fresco. Both are primarily in the sweet, chocolate, nut spectrum. I have frozen all types of coffee and haven't noticed a much of difference between them in this respect.
