Sir Anselm wrote:I just gotta ask, that twig in the first picture, was that included with the beans?
Haha, no that's a chop stick I used to sift through the fragments. Kinda reminds me of the bottom of the popcorn bucket, ya know?
another_jim wrote:The breaks in the Starbucks are not the sort you see in green coffee; these come from the roasted beans getting crushed.
Otherwise, I agree with Marshall that degunking your grind path with some GrindZ may be a good idea.
I think your initial idea of grind Starbucks came from conflating two separate things -- breaking in a the grinder versus setting it correctly. For breaking in, the best bet is to use a light roasted supermarket coffee, like 8 o'clock blend, and grind a few pounds slightly coarse. This will remove any burr irregularities, shavings, etc in the grind path.
For dialing in, pinch the grind between your fingers: it should be finer than table salt or sugar, but not quite a powder. Once you are at that point, you'll be close to the right setting; but you'll still need to pull shots to get it perfect.
Yes, my intention wasn't to break-in the grinder, so much as it was to play with my new grinder until my new machine arrives. This week should be fun... I have a Mini VII arriving (I hope), new tamper, a few other accessories and 5lbs of Red Bird.
If for some reason I can't get the Mini (I worked out a deal with a local vendor at SCAA Expo), I still have a Duetto on pre-order for the June shipment, as a backup plan. If that doesn't happen, I'll call up Stafano and buy one of his VBM Doubles. And if that doesn't happen I'll pimp myself out on the street and hustle my way into someone's GS3.
Uh huh, I have some GrindZ, that's a good idea.
