Need help with freezing Red Bird
Postby rhodges on Sat Jul 09, 2011 4:12 pm
Hi all i have been enjoying red bird espresso lately and decided to go ahead and pull the trigger on a 5lb bag. The only question i have is about freezing it. Does it come in 5 one pound bags, and if so is it okay to freeze in the bag it comes in? Or should i vacuum seal it? Any help would be greatly appreciated!
Thanks
rhodges
Postby germantown rob on Sat Jul 09, 2011 4:40 pm
Yes it will come in one 5lb bag. Repackage into containers that you will pull out once from the freezer to consume, I like mason jars, and let sit until ambient temp before opening, do not re-freeze.
germantown rob
Postby drgary on Sat Jul 09, 2011 6:33 pm
It comes in a 5 lb. Ziploc bag labeled with the roast date, and I got mine 2 days post-roast. The site says the best way is to vacuum seal it. If you can't do that, Jeff, the roaster/owner, told me to at least double bag it, especially if you have a frost-free freezer that sucks the moisture out. I put mine in several mason jars, packed full, no vacuum packing, and a couple of weeks later it's still delicious. I then take out a quart jar and go through that, enjoying its maturation as I drink it. Don't refreeze if you can avoid it. Freeze it right when you get it except that which you want to allow to mature. Jeff says it peaks at 7 - 10 days but is ready for espresso at day 4. Some people here will brew it non-espresso right after getting it too.
LMWDP#308
drgary
Postby Boldjava on Sat Jul 09, 2011 6:49 pm
I put mine in several mason jars, packed full, no vacuum packing, and a couple of weeks later it's still delicious. I then take out a quart jar and go through that...
I just drilled through a pint jar of RBird, prepared just as Dr G suggests. The crema was spectacular, as was the coffee in macchiatos and Gibraltars. I couldn't discern had been frozen.
B|Java
Boldjava
Postby Clint Orchuk on Sat Jul 09, 2011 7:42 pm
I just pulled the Red Bird at the market today and it was spectacular. I'll be buying 5 pounds a week from Jeff for the foreseeable future.
Clint Orchuk
Postby drgary on Sat Jul 09, 2011 7:53 pm
Boldjava wrote:I just drilled through a pint jar of RBird, prepared just as Dr G suggests. The crema was spectacular, as was the coffee in macchiatos and Gibraltars. I couldn't discern had been frozen.
And "drilled through" is a good way to put it. I've already gone through about half of mine and enjoy having a large quantity of a high quality blend for dialing in barista skills, such as they are! :mrgreen:
LMWDP#308
drgary
Postby rhodges on Sun Jul 10, 2011 10:15 am
Thanks a lot for the help everyone!
rhodges
Return to Coffees
