joel wrote:I've tried several techniques - dosing straight in to basket and tamping, dosing and tapping portafilter to settle grinds and tamping, dosing and stirring grinds then tamping - they all seem to produce the same result though.
Put away the whips and chains, and stop torturing your coffee. Try putting 14 grams into the basket, ground fine enough for a 30 second, 1.5 ounce shot, distribute it gently, tamp lightly and go. This may not be the best dose/grind/time/volume for your coffee, but it is what this and every other Italian espresso machine has been designed to do best. That means it is easiest to learn how to make good shots at that dose and grind.
Once you've mastered the machine at this dose, you'll be able to do others with a bit more
sprezzatura.
