by jonny on Mon Aug 01, 2011 2:58 pm
I agree that this is most likely the scales fault, but I want to address the freeze-thaw technique real quick to avoid other issues in the future. When you pull your sealed jar out of the freezer, water vapor in the air will condense on the beans if the jar is opened while they are still chilly (for the sake of the topic this would make your beans gain weight if anything but also make them go bad quicker and probably throw off your grind setting). You really want to be positive that the beans are up to room temp before exposing them. I generally take them out the previous night so I have no worries, but experience can determine how long it actually takes them to reach room temp. I would say much more than ten minutes (depending on the size of your jar of course) is necessary. An hour? Half an hour?If I have made a mistake and I don't have time to wait for beans to thaw, a take my smallest jar and sit it on top of my espresso machine for ten minutes or so or while I eat breakfast. I know heat is also an enemy to coffee bean freshness but I figure a short amount of heat is less bad and affects the grind less than letting moisture onto them. Also I only freeze in half pint and four ounce jars, so if I have lowered the quality of a jar of beans a bit, it's only a couple shots or so, and probably not a difference I can taste. I don't make this a habit though! Anyways, I am not a professional so take all of this with a grain of salt, but my common sense says this is reasonable advice.
